Dear Forum users,
We have deployed a SharePoint 2013 based CRM, internally in our organization and we are already using the SharePoint Lookup column webpart from SPARQUBE ->http://www.sparqube.com/SharePoint-Lookup-Column/ , because it provides more functionality and capabilities compared to default SharePoint lookup field, such as advanced filtering based on separated field, cross-site collection lookup support, create master record from detail form etc.
The problem is that the specific Lookup Column webpart is not compatible with SharePoint 2016 and SharePoint Online (2016).
Pls notice that we are going to upgrade our SharePoint 2013 to 2016 with plans for azure (online) but the internal CRM will be maintained on premises (CRM online is not included in transition at the moment for budget purposes).
We are looking for Lookup column functionality similar to sparqube webpart on SharePoint 2016 (Online).
Is it provided out out of the box (natively) in SharePoint 2016?
Do you know if there is such webpart available for SharePoint 2016 (Online) in SharePoint Marketplace?
I was thinking of proposing Layer2 SharePoint cloud connector. What do you think?
Any advise will bre much appreciated
Thanks in advance,
Cheers Nick
A lookup column is a referential integrity between the lists in SharePoint migration. It retrieves one or more values from a target list if those values match the value in the lookup column in the source list.
