Just wanted to share with you simple and low-cost SharePoint migrator.
p.s. You can request a free trial 🙂
http://blog.3pro.eu/products/sharepoint-migrator-50-discount/
About:
SharePoint Migrator is a Windows application for migrating SharePoint Document Libraries. This software enables quick and easy migrations of your documents from SharePoint on Premise to SharePoint Online (and vice-versa), SharePoint to File System, or File System to SharePoint.
The application is made as a tool for administrators, but it is designed to be simple enough so that semi-experienced SharePoint users can use it without problems.
Main features:
- Multiple paralel migrations
- Maintain versions
- Maintain Created / Modified fields
- Maintain Created By / Modified By fields
- Migrating from multiple libraries into one destination
- Setting Folder inside a library as a destination
- Automatch source and destination users
- Export/Import source and destination users
- Backup your files to FileSystem including all versions
- File and on screen logging
- Batch migrations via .bat or .cmd
Supported migration sources:Â SharePoint 2010 Foundation, SharePoint 2010 Standard, SharePoint 2010 Enterprise, SharePoint 2013 Foundation, SharePoint 2013 Standard, SharePoint 2013 Enterprise, SharePoint Online, File System.
Supported migration destinations:Â SharePoint 2010 Foundation, SharePoint 2010 Standard, SharePoint 2010 Enterprise, SharePoint 2013 Foundation, SharePoint 2013 Standard, SharePoint 2013 Enterprise, SharePoint Online, File System.
Here instead of trying any third part SharePoint Migration tool with blind trust, I would recommend you to use the official Microsoft SharePoint Migration tool. The SharePoint Migration Tool (SPMT) is a tool that migrates your files from SharePoint on-premises document libraries or regular file shares and easily copies them to your SharePoint on premise to sharepoint online migration tenant. It is available to all Microsoft 365 users.
The data view Web Part I must say is probably my absolute favorite thing Microsoft included with SharePoint. It also has some really nice filtering capabilities built-in. Most of us are probably familiar with the Sort and Group dialog that is part of the Common Data View Tasks shown in the image below.
What most people don’t realize is that the Data View Web Part has a very nice toolbar that can be used in the browser that will allow the user to choose their own sorting and grouping. To enable this toolbar, select Change Layout … from the Common Data View Tasks menu and select Show toolbar with options for: on the General tab of the Data View Properties dialog.
The default behavior of the filter row in the toolbar is to show a filter drop down for every column in the dataset. While this gives the user complete control of what they want to filter, it can also make the width of the web part very big.
Great !
Thanks for sharing this amazing tool. Being searching on my way with the same concern, I also find a nice application named LepideMigrator for Documents tool i.e,(http://www.lepide.com/lepidemigratordocuments/) that looks another comprehensive application while need to migrate document libraries from SharePoint.
Here is in-depth about LepideMigrator for Documents tool : http://www.lepide.com/blog/top-10-features-and-benefits-of-lepidemigrator-for-documents/
