Does SharePoint Online support SQL Report Builder? I just started at a new company that is using SharePoint Online and from what I am reading, it appears that it does not support SSRS (I’m hoping this is old data). In my previous position, I used SharePoint 2010 with SSRS and was able to create some very complex and advanced reporting documents. I was hoping to be able to do the same in my new position.
You can use SP lists as a datasource in an Excel workbook.
Hi Beth,
There is a SharePoint Add-In that you can use to render SQL Server Reporting Services (SSRS) reports in SharePoint Online pages
It’s currently free to use as well! 🙂
Hi Beth,
SSRS for SharePoint Online is available as a SharePoint App Service from ThorApps.
Its called Reflex Reporting for SharePoint Online.
Adrian
That’s disappointing. Do you know if there is a similar tool for reporting from SharePoint lists?
