Post Other Links and Category in Replies so I can add them to the guide!!
NOTE: Please find updated version with a lot more things over here: https://absolute-sharepoint.com/70-331-study-guide
| Skills Being Measured
This exam measures your ability to accomplish the technical tasks listed below.The percentages indicate the relative weight of each major topic area on the exam.The higher the percentage, the more questions you are likely to see on that content area on the exam. The information after “This objective may include but is not limited to” is intended to further define or scope the objective by describing the types of skills and topics that may be tested for the objective. However, it is not an exhaustive list of skills and topics that could be included on the exam for a given skill area. You may be tested on other skills and topics related to the objective that are not explicitly listed here.
Other Ressources
General Study
SharePoint 2013 training for IT pros
Hey, 1 link doesn’t work and the other is for SP 2010 🙁
Logical Architecture is discussed in the TechNet article entitled “Logical Architecture Components”, which can be found at http://technet.microsoft.com/enus/library/cc263121.aspx. Physical (Services) Architecture is discussed in the TechNet article entitled “Services Architecture Planning”, which can be found at http://technet.microsoft.com/en-us/library/cc560988.aspx
The hard disk space for database, transaction log, TempDb or any other space requirements for the SQL database server. These requirements will have to be assessed as part of your capacity planning and should be included in your completed design. Information about planning the storage and SQL server capacity planning can be found at http://technet.microsoft.com/en-us/library/cc298801.aspx , while overall information about SharePoint Server 2013 capacity planning can be found at http://technet.microsoft.com/en-us/library/ff758647.aspx
Planning and configuring the storage layer of a SharePoint farm infrastructure can be a complex task. For detailed information about each storage architecture, refer to the TechNet article entitled “Storage and SQL Server capacity planning and configuration”, which can be found at http://technet.microsoft.com/en-us/library/cc298801.aspx
For a detailed description of each search component and database, visit the article entitled “Overview of search in SharePoint Server 2013”, which can be found on TechNet at http://technet.microsoft.com/en-us/library/jj219738.aspx
