I have a lookup field named “Employee Info” that uses a lookup from a database. The main lookup comes as an underscored highlighted last name as a value ( I also opted use multiple fields tied to it such as Lastnamea and Firstname and employee ID.
I need to show the user if it is a duplicate.
I’ve tried using a workflow but I can’t seem to get it to work.
Is there any other way to determine if is a duplicate using for example, the employee id where if it is a duplicate set the value of field “status” to “duplicate”.
Thank you in advance.
(Visited 18 times, 1 visits today)
