I am able to configure BCS within SharePoint Online to display a list comming from SQL Azure.
I have found that I cannot map the SQL Azure (using BCS) to user properties in the user profile. The same works fine on premises.
I am not able to use the search online with BCS and I am not able to find a reference that I cannot do that.
Do somebody have the answer ?
Didier
