I have an external application (Contract manager) that has a unique ID for each contract. I have stored the documents for the contracts in a SharePoint RecordCenter library. That unique ID is one of the fields in my RecordCenter library. The unique ID field is not indexed and I already have 400,000 records so I cannot add an index to the field due to the SP throttling limitations. I need to be able to link directly to the documents from my external application, and the only field that can tie the contract record to the SharePoint record is this unique ID.
I have tried:
-using CAML query to filter down to the item I need. problem: I run into the throttling exception.
-using CAML query without a filter to return the throttle limit of items and then loop through them – this works but is extremely slow – like 30 minutes. this isnt acceptable obviously. I need something that takes less than 8 seconds.
Is there something I am missing in my approach?
*Update: I’ve tried using Search, but I am unable to guarantee that the single document I need is returned. Many times there are multiple documents that have metadata with a similar number (my unique ID) in another field. Also, I’m unable to serve up the returned docs automatically – I’m limited to displaying the search results page which isn’t optimal for this application.
*Update: I’ve had to resort to utilizing an external database to store the “Document ID” for each of my items so I can do a fast look up. This has the benefits of direct access to the document from CSOM, but the negative effect of requiring a resource outside of SP to enable the delivery of the documents. Not great, but it’s the best scenario I’ve been able to come up with.
Thanks for the reply. I’ve tried search and updated my post above with the issues I ran into.
Sure, check out the out of the box web part which looks up the document by DocumentId. It utilize search which might be considered the best option to work with the large amount of data in SharePoint.
So, the quick answers – use search.
