Hi All,
I am currently looking into a solution to utilize SharePoint REST API & CRUD to populate a custom HTML masterpage. For example update a carousel on the masterpage with content from a SharePoint list etc. I was wondering if anyone could provide some tutorials or examples.
Hi Vinny.
Any luck with “Using SP REST API”? Found any solutions?
This is the best rest/angular related article i’ve seen –http://www.dotnetcurry.com/sharepoint/1121/developing-sharepoint-2013-apps-angularjs
with the free 6 months subscription you can download code as well
Hi LarryÂ
I have found that the SharePoint Rest Api course on pluralsight to be quite helpful and has got me a lot further into finding a solution by using Json to create the dynamic HTML i needed
Please also let us know if you find a great solution…
