All,
Hope you all had a great start to the NY.. There is a scenario where I want to capture the web analytics and trends for private sites in SPO.. Have been looking into cardilog tool as well as web analytics (but this seems to work for Public website).. Any other suggestions or tools that you have seen/worked on that can be leveraged?
Hi Madan,
I have similar requirement to get analytics on on Private sites.
I appreciate if you can lead me some suggestions how to handle concurrent & type of usage reports.
Thank you Mark.. Yes that would work, but I wanted to check if it cud help me track information such as workflow statuses, concurrent users etc.. any similar scenario where you have used GA scripts?
Can you not use Google Analytics (or similar) and add the markup into the master page?
