I asked this question on my Facebook page and got some really good responses, so I thought I would cast it wider! I was wondering which MVVM Framework you all use with SharePoint and JS ?
The way I see it there are 2 main ones, with a 3rd option which is Kendo (paid) :
Do you use any of these ? If so which one and why ?
Man – I got some learning to do! I never heard of CoffeeScript. What is that — in a nutshell ?
Thanks Thorsten! I also just noticed you submitted a session on ShareCoffee. Not heard of that before, looks like a good library. Is it completely open source ?
Ah ok. We plan to use Angular or Knockout (not chosen yet), so will keep you informed.
BTW – you coming to SP24 ?
Head down, worky work worky makes for a dull boy!
Not faced that problem yet as only used it for ‘full page’ apps so don’t have to worry about what else is on the page.
Thanks Ryan! Long time no speak…
How do you deal with version conflicts and deployment ? i.e. what happens if a customer already has it included in the master page ? It’s a similar issue to JQuery, but with that you get NoConflict() to help.. Anything similar or isn’t this a major problem ?
