I am finding the way through which I can move all data from OneDrive to multiple accounts of Dropbox through one procedure.
You can try the OneDrive Migration tool through which you can easily migrate data from one account of OneDrive to various accounts of Dropbox accounts. You can easily transfer data through a single processing way. With this software, you can also try to migrate selective data as it allows you to transfer according to date or particular files type.
Step 1: Go to CloudFuze Move Screen.Â
Step 2: Select your source cloud and files ( Files from your Dropbox account).Â
Step 3: Select your destination cloud and folder ( OneDrive account and destination folder in OneDrive account).Â
Step 4: Initiate File transfer from your Dropbox account to OneDrive account.
Step 5: Confirm your move.
Undertaking any corporate migration whether it is SharePoint Migration or any other migration is a daunting task. When moving from OneDrive for Business to Dropbox, there are many things to consider.
Prior to migrating, it is important to gather all the information you need to run the migration smoothly. Make sure you have confirmed the information from the checklist below.
Migration Information Checklist
- Number of users to migrate
- Data ownership
- Data distribution
- Amount of data to move
- Number of files to move
- Individual file sizes and/or file sizes on average
- Who is your migration team?
- Who is your designated contact with us?
- Who is our point of contact with you?
You can try Mover for it. It will do your Job 🙂 But, if you want to perform some advanced migration you can try tools like Saketa SharePoint Migration Tool… any many other available in the market
This sounds like more of a DropBox question, you may want to head over to the dropbox forum to ask. Afaik, none of the popular storage providers, provide a mechanism for this.Â
May want to look into MultCloud or Mover.io
