Eurocom has laptop models with 64GB or RAM. They use a server board. For those feeling out-of-space with 32GB or RAM here’s the link:
http://web.eurocom.com/ec/ec_model_config1(1,233,0)x
These are pretty ugly laptops though.
HP EliteBook 8570W – Actually what I run – there actually quite a few variations of this model.
Another option is the HP EliteBook 8570W — 15.6″ display, up to 32Gb ram (only with quad-core processors though), built in msata drive slot (mine came with a 24Gb msata card set up as a cache of the 750Gb 7200rpm hard drive), but Crucial has a compatible 480Gb msata which I’ll consider just as soon as I can figure out how to make it the system drive.
One of the Lenovos makes you choose between a msata or 3g card — the HP allows both simultaneously, so if mobile broadband is important that might be an issue for you. I’ve also swapped in a Crucial 960Gb SSD for the hard drive, and if I need any more space I’ll look at changing the DVD for another 960Gb (or the new Samsung when it’s available).
So far I’m pretty happy with it — just haven’t tested it with a full sp2013 build yet (with OWA & AWF) but that’s coming very soon ….
It’s an Ivy Bridge processor setup, so as the Haswells are en-route you might see some end-of-line clearance bargains on these soon.
Hi Pham, thanks for the input. Do you have other recommended laptop for my needs? to conduct presentation and develop application in SharePOint. Thanks
