I will take a look at hMailServer as well . I have used smtp4dev which allows you to inspect the mail messages in a gui… I do want to set up exchange at some point to test overlays etc.
Daniel what do you use as a test Mail Server ?
I use hMailServer (http://www.hmailserver.com/) which is a freebie and very useful!
A low number of snapshots and yes you probably won’t notice it. Also merging/deleting old snapshots possibly helps.
Mark,
Coincidently, need to test out mail in my test domain so I will take a look at MailEnable and compare against setting up Exchange in its own VM.
Mark J’s recommendation of only going with one snapshot is probably good though I still remain to be convinced!
Interesting – that you both think it slows it down. I saw that in VMWare but not in Hyper V. All my machines have at least 1 snapshot and there’s never been a perf issue. However, I generally don’t have more than 2.
Snapshotting is essential for testing and so convenient!
