Hi all,
I’m new and newbie ^^
Can you help me please ?
I can’t solve my problem with my wiki pages.
After Database Attach upgrade I went on and did site collection upgrade.
The pages that worked in 2010 no longer work in 2013.
I get a javascript error when I try to modify them.
=> Uncaught TypeError: Cannot set property ‘ListId’ of nullSys._ScriptLoader._loadScriptsInternal @ ScriptResource.axd:5
It refers to :
document.getElementById('ctl00_PlaceHolderMain_WikiField_ctl00_ctl00_TextField_inplacerte').ListId = 'e2248123-245b-3972-8111-c3db7ee5g33a';
There's no particular customisation.
All upgraded contents works fine, just wiki crap :(
Any idea ?
Best regards,
Hi all,
I compare the 2 files in the subsite from 2010 and I can read for the file A :
This file is based on a file from the site definition. (and this file works fine)
The file B (bad upgrade/error in 2013) indicates me :
This file contains custom tags but I don’t see anything, I don’t see which tags, there’s no difference, only html contents are different.
So , what are the custom tags in sharepoint ?
Regards,
EM.
Hi Peter, many thanks !
Everything suggests that the update was successful but looking at some logs I can see it lacks features :
“WARNING Feature could not be upgraded”, “missing feature” or “file not found”
How to be sure that the migration and update worked well?
I get the 2013 functionnalities but in the central admin (get access finally ^^)
The state of the last upgrade tells me : “Failure”, it could be the reason ?
Regards,
EM
Not sure what could be the exact reason behind this issue. Even we faced lots of issues while migration from SharePoint 2010 to SharePoint 2013. As a workaround, if the content is still available to you of the wiki pages from the old SharePoint site, then better you re-create the wiki pages in SharePoint 2013 using markups, scripts etc, if required. It will help you to get things in place – Create and edit a wiki
How to Create a New Wiki Content Page in SharePoint: http://www.dummies.com/how-to/content/how-to-create-a-new-wiki-cont…
How do I create wiki pages in SharePoint 2013 using PowerShell script
You may also get help from this step by step guide to migrate from SharePoint 2010 to SharePoint 2013.
Hope this helps!
