Hi Team
I have requirement need to create the world document based on the below conditions.
1. SharePoint List will have actual data
2. SharePoint document library will have document template
3. when the user select the data and document template need to merge the value with document template and need to convert the file as document.
looking for solutions either in SharePoint 2010 & 2013 (onpremises and online)
Manikandan N
Hello Manikandan,
thats an easy task for our tool www.dox42.com.  To answer your questions:
1. Can be imported totally dynamic
2. Works totally fine
3. Also works with no code
The name of the product is www.dox42.com. I would be really happy if you try it. We can also set up a short free webinar to solve your problem in a live demo.
